Perform the following procedure to view Node Alias client information.
- Select Node Alias.
- Select the Client Info tab.
- Optional:
To clear a single client from the database, double-click an entry in the
EntryClear column.
- Select true.
- Select Apply.
Client Info Field Descriptions
Use the data in the following table to use the Client Info tab.
Name |
Description |
| MacAddress |
Displays the MAC address of the client. |
| Isid Index |
Displays details for the specified I-SID. |
| Vlan Index |
Displays details for the specified VLAN ID. |
| Isid Value |
Displays the I-SID value of the I-SID-to-VLAN assignment. |
| InterfaceIndex |
Displays the receiving interface port or MLT. |
| Capabilities |
Displays the protocols the client uses. |
| IsActive |
Displays if the client is active. |
| Ipv4Addr |
Displays the last IPv4 address used by this client. Note: Option 53 reads the IP address.
| Ipv6Addr |
Displays the last IPv6 address used by this client. |
| FirstLearnedTimer |
Displays the timestamp when the client was first detected on the port. |
| LastLearnedTimer |
Displays the timestamp when the client was last detected on the port. |
| EntryClear |
Clears the client entry from the database. |
| Hostname |
Displays the client host name. |
| OSType |
Displays the client operating system type. |
| DeviceType |
Displays the client device type. |
| OSVersion |
Displays the client operating system version. |
